D17 rpm governor failed
steve
11-17-1998 09:06:00
My AC D17's rpm governor has failed - the engine just revs way high and the steering wheel throttle lever has no effect. All linkage seems o.k. ,and I can manually control rpms by moving the throttle rod that connects to the carb. Anybody out there know about this stuff? Thanks, Steve.
Bill
11-17-1998 11:34:51
 Re: D17 rpm governor failed in reply to steve, 11-17-1998 09:06:00
Steve: It sound to me like you have a broken gov. weight. If so, you should not run the engine until fixed. The gov weight have hard metal pieces attached to a soft alloy. If this hard piece gets picked up by a timing gear, Real BAD news. It will bust thing to pieces. Pull your distributor and inspect gov. assembly immediately. Good luck, Bill
Lloyd
11-18-1998 23:13:09
 Re: Re: D17 rpm governor failed in reply to Bill, 11-17-1998 11:34:51
: Steve: It sound to me like you have a broken gov. weight. If so, you should not run the engine until fixed. The gov weight have hard metal pieces attached to a soft alloy. If this hard piece gets picked up by a timing gear, Real BAD news. It will bust thing to pieces. Pull your distributor and inspect gov. assembly immediately. Good luck, Bill
My weights broke along with the casting mounts they're hooked to. Cost me $700 to fix it. Had to get all new gov, weights, springs, and timing and crankshaft gears.
