WD 45
Jeff Reeves
05-28-2000 18:38:18
1942 WD45: I replaced the head gasket on my step dads 45 and it will not start. I torqued the head bolts to 100 Lbs of torque, drained the gas in the tank and carburator,replaced the spark plugs and changed the oil. The tractor is getting fire to the spark plugs, and there is gas going to the carb, but it wont start.What is the firing order?Where is number one wire on distributor cap? Help!
Dave K.
05-30-2000 16:52:58
 Re: WD 45 in reply to Jeff Reeves, 05-28-2000 18:38:18
Just being hit picky but a WD-45 can't be a 1942 model!
Dave
Dick L
05-28-2000 19:06:09
#1 plug wire should come out of the cap closest to the block and closest to radiator. #2 plug wire next clock ways or closest to radiator and farthest from the block. #4 plug wire is next clock ways from #2 plug wire and #3 plug wire is next clock ways from #4 plug wire. #1 plug is the closest plug to the radiator. Fireing order is 1-2-4-3
