WC Backfires
Bud
05-28-2000 18:24:56
I removed my coil and distributor cap to paint them. After reinstalling them the engine won't start and I get a loud backfire after it cranks over a few times.I have spark at the plugs and the plug wires are connected 1243 assumming a clockwise rotation of the distributor which seems correct.
Help, I'm lost.
Thanks
Bud
Dick L
05-28-2000 18:47:30
 Re: WC Backfires in reply to Bud, 05-28-2000 18:24:56
Bud, I just posted below and after reading this post and you have checked spark to your plugs, and clock ways is correct, it has to be out of time or not enough fuel. They don't usualy backfire on start up with a lack of fuel. Make sure #1 piston is on its way up on the compression stroke, take #1 plug out at the (front of the engine next to the radiator,) put your thumb over the hole and when it starts to build pressure start looking for the fire mark on the flywheel. When the fire line is centered your rotor should be pointing at the #1 distributor cap terminal and the points just ready to open.
