B parts
Larry G
05-26-2000 04:42:30
Im looking at a 49 B for parts for my freinds 39 B. will the front end ,rear wheel hubs etc. interchange? I assume this is a 49 because of date stamped on rear left axel. appreciate any help. thanks!
Larry G.
05-26-2000 09:48:18
 Re: B parts in reply to Larry G, 05-26-2000 04:42:30
where is the SN located on this B? Thanks! Larry
RA
05-26-2000 11:32:10
 Re: Re: B parts in reply to Larry G., 05-26-2000 09:48:18
The serial number is located either just ahead of or behind the shifting lever on a flat area. I can never remember which side until I go look at mine. Hope this helps.
Phil Auten (TX)
05-26-2000 05:31:21
Larry,
I'd check the S/N to be sure of the vintage. The axle may have been swapped out previously. Parts should fit anyway.
Phil
