Hydraulic pump
Farmboy
05-25-2000 19:40:40
I would like to add a hydraulic pump that runs off the front of the crankshaft to my WD that I'm rebuilding. Is there an easy way to link it to the crank and still use the same pulley? It looks impossible, are there other pulleys or adapters for this?
Thanks
Farmboy
C.J.
05-27-2000 14:40:25
 Re: Hydraulic pump in reply to Farmboy, 05-25-2000 19:40:40
I am not sure if this will help you, but I added a front pump to my D-17. The pump came off of a ford tractor. It had a four bolt hub that mounted perfect to my D-17. Ford offered three different length shafts for the pump, and the longest one worked on my D-17. You might see if a wd and a D-17 have the same crank pully or see if a D-17 pully will mount on a wd and go with fords linkage.
Anthony Donner
06-23-2000 10:28:33
 Re: Re: Hydraulic pump in reply to C.J., 05-27-2000 14:40:25
what model ford tractor did it come off of, i am trying to do this with my d-17 and canot find a hub to do this
