U joint on input shaft b model alis chambers
steve johnson
05-25-2000 15:29:01
we need help finding an upgrade or replacement for this u joint. no one we talk to seems to have any ideas. any help would be greatly appreciated.
Paul from Michigan
05-25-2000 19:46:04
 Re: u joint on input shaft b model alis chambers in reply to steve johnson, 05-25-2000 15:29:01
My parts book show #223273 assembly as a replacement for the older U-joint type assembly. The new one is a splined sleeve coupling type. Probably you can find the newer type used. Try Roger Vanamp 219-747-3455 for a used one. good luck, Paul
