C engine problems
chip
04-30-2000 17:49:55
I have a C that runs poorly. I've replaced points condensor, wires, plugs to no avail. When I crack the petcock on the intake manifold open a bit it runs better, so I cleaned out the air cleaner screens, but still didn't help. Put in carb kit, no better. Any ideas?
Dick L
04-30-2000 21:15:08
 Re: C engine problems in reply to chip, 04-30-2000 17:49:55
Opening the petcock will reduce the amount of vacuum that pulls gas from the carburetor
that should slow the engines RPM's. I would have to guess that if it sounds better at a slower RPM that your not getting enough gas from the tank to the carburetor. Take the gas line off at the carburetor and check the flow. If you have cleaned the tank and checked the lines you might want to take the shutoff valve all the way out. Gunk can build up in this valve that has to be scraped off. Just a guess but I have seen it happen. Good Luck and let us know what you find.
