AC C new owner question
D from WA
04-30-2000 10:50:15
I just recieved an AC C. I have heard that they can be positive ground. Does any one know if that is right, and if so how do I check if mine is. Also, if it is positive ground can someone please verify to me how the battery hook up is. I want to make sure that I dont mess anything up when I hook up the battery for the first time. Thanks everyone. I know this is a bonehead question, but "Better safe, than sorry".
Phil Auten (TX)
04-30-2000 14:57:41
 Re: AC C new owner question in reply to D from WA, 04-30-2000 10:50:15
D,
All C tractors were 6V Positive Ground. If someone has converted it to 12V, it probably has an alternator and is negative ground. As long as the tractor has a generator, it should be positive ground.
Phil
D
04-30-2000 15:10:12
 Re: Re: AC C new owner question in reply to Phil Auten (TX), 04-30-2000 14:57:41
thanks Phil! It does have a generator, although I was told it does not work, and has been disconnected. Just to make sure I understand, since it is positive ground, do I hook the positive terminal on the battery to the ground and the negative terminal to the starter?
Larry M
04-30-2000 17:56:49
 Re: Re: Re: AC C new owner question in reply to D, 04-30-2000 15:10:12
Thats correct, you hook the positive terminal to ground and the negative terminal to the starter.
Bud
04-30-2000 14:17:19
I'm no expert but I'm pretty sure that if it has a magnito it will have a positive ground. Conversly if it has been converted to a distributor it will also have been changed to a negative ground.
Gordon Chance
04-30-2000 16:50:35
 Re: Re: AC C new owner question in reply to Bud, 04-30-2000 14:17:19
Bud:
It make no difference whether it has a magneto or distributor for the polarity of the ground. If it has a generator it should be positive ground and if it has been converted to 12 volt with an alternator then it should be negative ground. I hope that this helps.
Gordon
