Name that Carburetor
Nils Noack
04-27-2000 07:45:14
Could someone please help me to identify the brand of carburetor on my WD. The one on the tractor has no name or numbers stamped or cast into the unit. It is cast iron. It has external idle and high speed adjusting screws. The high speed adjusting screw is at the bottom of the bowl and is parallel with the mounting flange. From the above can anyone tell me if it is a Marvel-Schebler or a Zenith? Can I also get a recommendation of good mail order source for a carburetor overhaul kit? Thank you
Matt
04-27-2000 13:57:25
 Re: Name that Carburetor in reply to Nils Noack, 04-27-2000 07:45:14
It is a Zenith. The Marvel-Schebler carburetors' load screw is at a 45 degree angle. If you don't tell anyone, I can rebuild your Zenith carb for $50.00 (includes shipping) The Marvel-Schebler can be rebuild for $40.00
Matt
Sandy Lake Implement
04-28-2000 20:35:55
 Re: Re: Name that Carburetor in reply to Matt, 04-27-2000 13:57:25
It does sound like the Zenith. We stock rebuild
parts for them & the MS. Usually just need gaskets
& needle/seat asy.
