WD45 electrical system
Marek Christer
11-11-1998 06:56:00
I recently bought a house that had a WD45 included. After standard fixup (plugs, filters, points, etc.), the tractor runs great, except the battery is not being charged. I discovered that the previous owner did install a 12 volt battery.
If I replace the generator and the voltage regulator with 12 volt devices, are the starter and the ignition coil going to survive? Can I find these two in a 12 volt version somewhere?
orangeman
11-13-1998 11:46:20
 Re: WD45 electrical system in reply to Marek Christer, 11-11-1998 06:56:00
Mark, check the archives under 12 volt conversion under the ac and the Ford discussion pages. There is a wealth of info. on this topic.
: I recently bought a house that had a WD45 included. After standard fixup (plugs, filters, points, etc.), the tractor runs great, except the battery is not being charged. I discovered that the previous owner did install a 12 volt battery.
: If I replace the generator and the voltage regulator with 12 volt devices, are the starter and the ignition coil going to survive? Can I find these two in a 12 volt version somewhere?
