Two WD questions
Tom in Minnesot
04-25-2000 20:56:33
1. What are headbolt torque specs for 1951 WD and how in the @*#$** do you get a torque wrench on those two little buggers under the water manifold.
2. Will a WD pull three 14's in light sandy soil??
Dave Kolby
04-30-2000 18:51:06
 Re: Two WD questions in reply to Tom in Minnesota, 04-25-2000 20:56:33
I use an AC Snap cpupler 3/14 on my 1948 WD in sandy loam with no problems. No fluid in the tires but have AC wheel weights on it.
Dave
Richard (KS)
04-26-2000 14:05:30
The WD should pull a 3-14 plow OK especially in light sandy soil. The Snap Coupler plows and such work really well with the Traction Booster introduced on the WD.
Phil Auten (TX)
04-26-2000 04:54:17
Tom,
Head bolt torque for the WD is 70 ft/lbs. Try removing the water manifold, or is it part of the head?
For all the torque specs, use the link below.
Phil
mike schwartz
04-26-2000 21:29:58
 Re: Re: Two WD questions in reply to Phil Auten (TX), 04-26-2000 04:54:17
Tom,
To tighten the two headbolts under the thermostat housing I used my crowfoot wrench with a 3/8 to 1/2 adapter to attach to my torque wrench. There was not much room so I got them as close as I could with a regular open end wrench first. I don't know if this is the right way or not but it worked for me. Good luck, Mike.
CP's/AC's
04-27-2000 13:23:01
 Re: Re: Re: Two WD questions in reply to mike schwartz, 04-26-2000 21:29:58
I put 3 washers lubed with grease on the housing studs, without the housing, then torqued head in increments to spec. When done, just remove the housing nuts and washers, install housing, and tighten with 3/4 in. wrench just shy of over tightening and ruining the paper housing gasket. Carroll
