CA and Woods Belly Mower
Tom Westerfield
11-10-1998 17:52:33
Have a '52 CA Allis with a aftermarket 3 point hitch. Can anyone advise regarding the connectivity for a Woods belly mower?
Thanks!
Dave Straka
11-11-1998 19:21:20
 Re: CA and Woods Belly Mower in reply to Tom Westerfield, 11-10-1998 17:52:33
: Have a '52 CA Allis with a aftermarket 3 point hitch. Can anyone advise regarding the connectivity for a Woods belly mower?
: Thanks!
Tom:
I have a "B" with a 3pt and a woods belly mower and everything works
just fine.
Dave
Tom Westerfield
11-12-1998 03:19:48
 Re: Re: CA and Woods Belly Mower in reply to Dave Straka, 11-11-1998 19:21:20
: : Have a '52 CA Allis with a aftermarket 3 point hitch. Can anyone advise regarding the connectivity for a Woods belly mower?
: : Thanks!
: Tom:
: I have a "B" with a 3pt and a woods belly mower and everything works
: just fine.
: Dave
Thanks Dave. Where do you have the belt idler pulleys mounted?
Tom
Dave Straka
11-13-1998 16:59:55
 Re: Re: Re: CA and Woods Belly Mower in reply to Tom Westerfield, 11-12-1998 03:19:48
: : : Have a '52 CA Allis with a aftermarket 3 point hitch. Can anyone advise regarding the connectivity for a Woods belly mower?
: : : Thanks!
: : Tom:
: : I have a "B" with a 3pt and a woods belly mower and everything works
: : just fine.
: : Dave
Tom:
Is this a trick question???? They are mounted on the mounting bracket
that Woods supplies. You do have that bracket, don't you??? You can
buy that bracket by itself,(I did) It runs about $180.00. The idler pulleys are about $50.00 each. Woods was very helpful when I was putting my together. They will fax
you instalation instructions.
Dave
: Thanks Dave. Where do you have the belt idler pulleys mounted?
: Tom
Tom Westerfield
11-13-1998 17:18:31
 Re: Re: Re: Re: CA and Woods Belly Mower in reply to Dave Straka, 11-13-1998 16:59:55
: : : : Have a '52 CA Allis with a aftermarket 3 point hitch. Can anyone advise regarding the connectivity for a Woods belly mower?
: : : : Thanks!
: : : Tom:
: : : I have a "B" with a 3pt and a woods belly mower and everything works
: : : just fine.
: : : Dave
: Tom:
: Is this a trick question???? They are mounted on the mounting bracket
: that Woods supplies. You do have that bracket, don't you??? You can
: buy that bracket by itself,(I did) It runs about $180.00. The idler pulleys are about : $50.00 each. Woods was very helpful when I was putting my together. They will fax
: you instalation instructions.
: Dave
: : Thanks Dave. Where do you have the belt idler pulleys mounted?
: : Tom
Good info Dave. Thanks! No, I don't have the brackets, just the deck. Do you have an address/phone for Woods?
Thanks if you do or thanks if you don't.
Dave
11-14-1998 08:05:09
 Re: Re: Re: Re: Re: CA and Woods Belly Mower in reply to Tom Westerfield, 11-13-1998 17:18:31
: : : : : Have a '52 CA Allis with a aftermarket 3 point hitch. Can anyone advise regarding the connectivity for a Woods belly mower?
: : : : : Thanks!
: : : : Tom:
: : : : I have a "B" with a 3pt and a woods belly mower and everything works
: : : : just fine.
: : : : Dave
: : Tom:
: : Is this a trick question???? They are mounted on the mounting bracket
: : that Woods supplies. You do have that bracket, don't you??? You can
: : buy that bracket by itself,(I did) It runs about $180.00. The idler pulleys are about : : $50.00 each. Woods was very helpful when I was putting my together. They will fax
: : you instalation instructions.
: : Dave
: : : Thanks Dave. Where do you have the belt idler pulleys mounted?
: : : Tom
: Good info Dave. Thanks! No, I don't have the brackets, just the deck. Do you have an address/phone for Woods?
: Thanks if you do or thanks if you don't.
Tom:
Here is the Woods home page they will be able to help you.
Good luck.
Dave Straka
Just click on the "highlighted" Woods
Tom Westerfield
11-14-1998 15:04:02
 Re: Re: Re: Re: Re: Re: CA and Woods Belly Mower in reply to Dave, 11-14-1998 08:05:09
: : : : : : Have a '52 CA Allis with a aftermarket 3 point hitch. Can anyone advise regarding the connectivity for a Woods belly mower?
: : : : : : Thanks!
: : : : : Tom:
: : : : : I have a "B" with a 3pt and a woods belly mower and everything works
: : : : : just fine.
: : : : : Dave
Thanks Dave, I got it and will contact them. You've been a great help.
: : : Tom:
: : : Is this a trick question???? They are mounted on the mounting bracket
: : : that Woods supplies. You do have that bracket, don't you??? You can
: : : buy that bracket by itself,(I did) It runs about $180.00. The idler pulleys are about : : : $50.00 each. Woods was very helpful when I was putting my together. They will fax
: : : you instalation instructions.
: : : Dave
: : : : Thanks Dave. Where do you have the belt idler pulleys mounted?
: : : : Tom
: : Good info Dave. Thanks! No, I don't have the brackets, just the deck. Do you have an address/phone for Woods?
: : Thanks if you do or thanks if you don't.
: Tom:
: Here is the Woods home page they will be able to help you.
: Good luck.
: Dave Straka
: Just click on the "highlighted" Woods
Dave
11-14-1998 08:02:18
: : : : : Thanks!
: : : : Tom:
: : : : just fine.
: : : : Dave
: : Tom:
: : Dave
: : : Tom
Tom:
I have given you the Woods home page. Just click on it and it should take you
to it. The page has a toll free number in the lower left corner.
Good luck.
Dave
