Welding
Butch Carver
11-09-1998 18:12:16
Need some tips on vertical arc welding, or some links with some informative reading on arc welding.
Koeckeritz Exc.
11-18-1998 01:59:43
 Re: welding in reply to Butch Carver, 11-09-1998 18:12:16
: Need some tips on vertical arc welding, or some links with some informative reading on arc welding.
: : Lincon Welding has good book on arc welding,Procedure Handbook of Arc Welding,I have 12th edition, good refrence sourse.Vert welding is practice,rod,heat range,application.Vert down is looks only or light metal.Vert up for penatration,strength.Fast freeze rod flux important.wipping rod for larger gaps,wire feed works good on clean metal with right heat / feed rates. Check with welding supply house for rod handbooks good info low/no cost.
Peter
11-10-1998 14:08:57
Should of posted this at JD because all their stuff needs repairing
Cliff
11-14-1998 19:59:57
 Re: Re: welding in reply to Peter, 11-10-1998 14:08:57
: : : Need some tips on vertical arc welding, or some links with some informative reading on arc welding.
: Should of posted this at JD because all their stuff needs repairing
: the best way to weld it, get someone who knows how to weld! Or spend a lot of time practicing!!!!
greg reuter
11-21-1998 19:26:16
 Re: Re: Re: welding in reply to Cliff, 11-14-1998 19:59:57
Reorient for down-hand if you can.
Otherwise, if you have access to a wire-feed
or mig welder with adequate capacity, use it.
It will make gravity less of a problem.
: : : : : Need some tips on vertical arc welding, or some links with some informative reading on arc welding.
: : Should of posted this at JD because all their stuff needs repairing
: : the best way to weld it, get someone who knows how to weld! Or spend a lot of time practicing!!!!
