WD45 runs worse as it warms up
Rail
04-22-2000 21:23:40
The tractor starts and runs well at first but after about 5 minutes it sounds like it misses every once in awhile. This continually gets worse until after 20 minutes it's bearly running.
It's worse when using the mower. I've taken the carburetor apart and cleaned it several times but this hasn't made a big difference. What could cause this and how can I check it out?
Dave Kolby
04-23-2000 08:52:07
 Re: WD45 runs worse as it warms up in reply to Rail, 04-22-2000 21:23:40
Mine was doing that and I found the condenser in the magneto was bad. Cleared it right up. Suppose if you have distributer ign it can still be the condenser, worth a try, cheap to buy.
Dave
Grandad (MI)
04-23-2000 09:48:27
 Re: Re: WD45 runs worse as it warms up in reply to Dave Kolby, 04-23-2000 08:52:07
With distributer ignition it could be the coil also.
CP's/AC's
04-23-2000 09:15:48
Dave, also check for restriction of fuel at tank, filter,etc.
