[ PLEASE HELP]
JOHN LAW
11-09-1998 09:20:24
I would like to know how to time the main pump with
the cam shaft.It is a 1969 diseal
thank you
Mory
11-09-1998 12:39:28
 Re: [ PLEASE HELP] in reply to JOHN LAW, 11-09-1998 09:20:24
: I would like to know how to time the main pump with
: the cam shaft.It is a 1969 diseal
: thank you
I presume this is a roosa master. Take the small cover off 2 screws find the timing marks on engine either on damp. pully or the flywheel rotate engine with wrench till timing mark is aligned with arrow. then check pump timing if it is off make 1 more revolution of engine then it should be aligned. If you have to ask how to do this you should hire someone who is experienced because there is no room for error on these devices.
Evan
11-09-1998 12:30:57
: thank you
What engine? What pump?
