B Value?
DCCasey
04-21-2000 19:36:38
I found a B serial # o304 in good shape . What is it worth? Good rear tires needs paint job not rusty.
D13
04-21-2000 19:58:06
 Re: B Value? in reply to DCCasey, 04-21-2000 19:36:38
Pplease check your serial number again. The serial number usually starts with B, like the posting below yours. If it is a B, and the serial is 0304, it's a very early tractor, should be hand start, magneto, hand brakes, the engine serial number (left side, on the torque tube flange) shuld begin with "BE", and the front wheels should be riveted to the front hubs. If this is so, then it is a true early "collector", and would be worth about $2000 running. If the serial number is over 1000 but less than 3000 it's still collectable and probably is in the $12-1500 range. If the serial is over this $600 with hand start, $1000 with electric would be the max. Dealers are asking $900 for hand cranks but not moving them at that price. If it is an early unit and you don't buy it email me at [email protected], I may have a man who would buy it as a restoration project.
