Allis Chalmers 1942 WC #117501
Todd Langdon
04-18-2000 18:45:44
I would like to convert this to a 3point hitch and add some hydrolics. Can anyone out there make any suggestions???
D13
05-29-2000 06:10:05
 Re: Allis Chalmers 1942 WC #117501 in reply to Todd Langdon, 04-18-2000 18:45:44
I have seen several methods. Nrothern Hydraulics sells belt drive pumps that you can run with the engine. My B has a power steering pump set up to power a single cylinder (low pressure). Notrhern also sells PTO powered pumps. You can make your own 3-point set up, although there may be someone who makes them (Cross mfg in Missori?) for $350-450. By time you're done, unless you're handy and a good scrounger, you'd be better off buying a later machine (say, WD45 or D17)) with the setup already on it. Of course, if you're fond of the WC, and you like to tinker, by all means do it!
Dave
06-13-2000 14:19:06
 Re: Re: Allis Chalmers 1942 WC #117501 in reply to D13, 05-29-2000 06:10:05
I have WC 177805 and its a 46 complete. Ide like to sell it but have 2500 in overhaul . Any suggestions?
Phil Auten
04-19-2000 05:20:26
Todd,
I'd suggest an engine driven pump driven with a belt off the crank pulley. Another alternative is a 12V electric pump as is used on hydraulic liftgates on delivery type trucks. That would require a 12V conversion, but since you want a 3-pt. hitch, I suppose this will be a working tractor. Either way will work, with the engine driven pump being my choice.
Phil
