WD 45/WD manifold
Chuck
04-16-2000 11:16:56
Will the manifolds from a WD and WD 45 interchange? Also will it work to change the heads by just using longer head bolts for the WD 45 head?
Thanks
Aaron
04-16-2000 16:25:16
 Re: WD 45/WD manifold in reply to Chuck, 04-16-2000 11:16:56
You can do all of that. The 45 head will work fine with the 45 studs, the manifolds will interchange, the crank, almost anything that will bolt onto or fit in the block can be changed.
Aaron
