D-15 loader
Larry
04-15-2000 04:59:34
I just bought a early D-15 Allis. It there a slick way to put a diverter valve or tie into the system on the existing Hyd. pump to run two way cylinders on the lift and tilt rams. I have a pto pump I could use but hate to tie up the pto. It has a single output hyd coupling but not for two way operation. thanks for your input. Also what kind of problems will the old high pressure low volume cause me with a newer low pressure and higer volume loader rams.
Dave
04-15-2000 05:39:23
 Re: D-15 loader in reply to Larry, 04-15-2000 04:59:34
Larry
The best thing that I can think off is to mount a hyd. pump on the front of the tractor. You can buy a bolt on unit that has a shaft that runs from the flywheel pully to the pump. I have two d15s and two loaders. This is the best system because the hydralic power is always live.
