WD-45 fuel leak
Dale Wyttenbach
04-13-2000 09:49:06
My WD-45 leaks fuel at the sediment bowl/fuel
shut off area. I can't exactly identify the source of the leak, but suspect it is either the gasket that the glass bowl presses against or a
gasket in the shutoff. It doesn't leak enough to leave a puddle but it leaks enough to smell, so the wife says I can't have the tractor in the attached garage until I fix this.
Are these gaskets readily available and/or can I buy an new bowl/shutoff assembly for a reasonable price?
fatboy
04-18-2000 10:57:59
 Re: WD-45 fuel leak in reply to Dale Wyttenbach, 04-13-2000 09:49:06
you are better off just replacing the assembly
I had the same problem. your local AGCO dealer has
them in stock for about $25.00
Brian G.
04-14-2000 05:44:46
Dale, "tadams" is correct about the possibility of the ass'y. being "warped" (a fairly common thing), however, since it leaks so little, a new gasket would probably do the trick. I would also tighten the packing nut on the valve if it hasn't already been tightened to the max.
tadams
04-14-2000 04:43:08
NAPA carries both gasket and complete assenbly. You are better off to replace complete assemby because most of the time someone over tighten the sediment bowl and warped metal, and a new gasket will not seal.
Tom
David
04-13-2000 10:51:10
Central Tractor lists the entire fuel sediment bowl assembly for $30, or the gasket for $2. Tracter Supply or AGCO also should have them for about the same money.
