Wd power steering
pete
04-09-2000 15:50:52
does anybody know if I can put power steering on my 1952 wd. I have a char-lynn power steering motor.will the pump on the tractor work or do i need someting else. thank you.
Will Powell
04-09-2000 19:06:47
 Re: wd power steering in reply to pete, 04-09-2000 15:50:52
You will need an external pump, it must always be live. If you use the internal pump it will shut
off the power streering every time you pull in the clutch. I have seen a WD with the Char-lynn
power unit. The power unit is supplied by a pump
mounted above the water pump. You will most likely
need a crankshaft pully made for two belts.
Gene
05-27-2000 16:08:22
 Re: Re: wd power steering in reply to Will Powell, 04-09-2000 19:06:47
A friend of mine used a steering pump from a chevy truck and the char-lynn motor and worked fine. You will have to use another external pump
