Gleaner combine engine info
jocko
04-08-2000 13:30:50
I would like some info on a Gleaner C combine engine that I just purchased. I belive the engine is a 262c.i. gas model, and I would like to get as many specs on this engine as possible (including horsepower,and cam specs). This engine is going into a D-19 that I use in a tractor pulling circuit. thank you, M bros pulling team
john T.
04-11-2000 16:45:13
 Re: gleaner combine engine info in reply to jocko, 04-08-2000 13:30:50
the 262 gas engine has a compression ratio of 8:1,the lp gas engine has a compression ratio of 9.25:1,at 2300 rpm,the combine engine is the same except the govenor.
Brian Ahart
04-08-2000 16:11:37
This is indeed the 262 CID gas engine used in the D19. This engine was rated at 71 HP in the D19 (I would assume a similar rating in the combine). I had a D17 Series III with a 262 gas (tractor was formerly a diesel). With a 4 inch straight pipe, it would turn a few heads when I opened her up...
Good luck. I know you'll enjoy the project.
Brian
