D17 ser. iv
Bruce
11-02-1998 09:24:57
The lever on the right hand side of the operator> Is it a high / low range or a hand clutch.
Kris Rutko
12-12-1998 17:23:32
 Re: d17 ser. iv in reply to Bruce, 11-02-1998 09:24:57
: The lever on the right hand side of the operator> Is it a high / low range or a hand clutch.
Yep, all of the above. Shift the tractor into neutral when dismounting. Just putting the hand clucth in the neutral position isn't safe. My D17 wants to drift forward when the hand clutch is in the N position until I hit the brakes.
JK MN
11-02-1998 19:10:50
Bruce, All of the above. Plus it's an on the go shift. Back is low range, Middle is neutral, Forward is high range. One Caution however, the middle position is intended to stop the tractor when using the PTO, and this position gives "Live PTO". Be sure to shift the transmission into neutral when getting off the tractor. DO NOT rely on the middle positon for neutral.
