12volt conversion
Mark
04-06-2000 20:32:58
just converted over to 12Volts as per the article in this mounths online mag. as described in the article it sounds like i need that darn diode. what do i ask for at the auto parts store? or is there another solution? the tractor keeps running after it is shut off, even after disconnecting the positive battery cable. THANKS
ralph
06-04-2000 20:14:37
 Re: 12volt conversion in reply to Mark , 04-06-2000 20:32:58
mark what online mag did you see that artical in thanks
micheal
04-07-2000 20:46:39
go to Radio Shack and ask for a ON or Mot 1N4004 diode.
should do the trick. you want something in the 3A range.
micheal
JOHN IN NY
04-07-2000 04:49:34
THE BEST PLACE TO GET THEM IS RADIO SHACK. 2 IN A PACKAGE FOR 49 CENTS.
Hilltopper
04-07-2000 13:40:42
 Re: Re: 12volt conversion in reply to JOHN IN NY, 04-07-2000 04:49:34
On my 12 volt conversion the hot side of the coil goes through the ignition switch. Switch off, no power to coil. I thought all the conversions were wired this way.
Richard (KS)
04-07-2000 13:46:55
 Re: Re: Re: 12volt conversion in reply to Hilltopper, 04-07-2000 13:40:42
The problem is that the field circuit of the alternator feeds back through the system and keeps the coil energized. Where I work we commonly run the field excitation through an oil pressure switch, or you could use a double-pole single-throw switch, to switch the field current independently of the ignition and other "B+" circuits.
