Gear Shifter build up
M.Beam
04-05-2000 19:47:37
I have a WD45 and the shifter keeps snapping loose. I hear you could build up the end of it by welding it. Which way do you build up? The flat ball shaped end? Should I round the ball or leave flat and extend size of ball? I dont know what it is suppose to look like.
Thanks
ARTY IN MO
04-21-2000 20:06:46
 Re: Gear Shifter build up in reply to M.Beam, 04-05-2000 19:47:37
THE TIP IS SQUARED OFF ON SIDES AND ROUNDED ON FRONT AND REAR. TRY LENGTHENING THE END AND I BELIEVE THE BOTTOM IS SQUARED TOO. GOOD LUCK.
Dan
04-25-2000 17:00:18
 Re: Re: Gear Shifter build up in reply to ARTY IN MO, 04-21-2000 20:06:46
Do you have any thoughts as to how long you can extend the shifter tip before it causes trouble ? I have the same problem with a WD45 shifter slipping out of the fork assembly. I wonder if I built it up 1/2 inch if that would be too long?
