Replacing bushings/bearings for front support steering arm
Duane
04-05-2000 10:56:40
I have to replace the bushings/seal in the front support steering arm shaft on my wide front-end C. Has anyone done this before and can give me pointers? I can't seem to get the gear off the one end so I can slide the shaft out. I took the set-bolt out of the gear but it is still stuck on pretty good. Should I heat the gear up to loosen it? I tried a liquid wrench product to no avail. Also, does anyone know where I can get all of the bearings/seals/bushings for the front support? One place I tried did not carry the bottom bearing and seal. And another question - The manual says I should pack both the upper and lower bearings with No2 bearing grease, but when I put 250 gear lubricant in the box won't it fill into the lower bearing? Any help is appreciated.
thanx.
Hamster
05-26-2000 21:38:14
 Re: Replacing bushings/bearings for front support steering arm in reply to Duane, 04-05-2000 10:56:40
You can get the bearings and seals from your Allis dealer or take the old one to a good automotive parts house and they will cross-reference. Take the shaft diameter along to be certain they get the correct seal ID.
jack
04-06-2000 15:34:03
Just finished doing the same on my wide front model C. Once you have the set bolt removed you go to the "heat & beat" technique. Heat the gear, but don't get it too hot(by that I mean not cherry red). Try to heat it uniformaly. Take a brass drift and try to "tap" on opposite sides of the gear. It should come off with a little persuasion.
