Allis-chalmers WD
Randy
04-02-2000 16:05:15
i shut it off after running it for an hour.it won't start up.there is no spark coming off the plugs.it has a magneto.i would appreciate any help on troubleshooting this problem and any solutions.
Rick
08-18-2001 22:24:23
 Re: allis-chalmers WD in reply to Randy, 04-02-2000 16:05:15
If all of your ignition parts such as points, condensor, cap, rotor, plugs, and wires are all in fairly new or good condition you won't have to look much further than replacing the ignition coil. It is not uncommon for coils to open up a winding when hot, then when the coil cools, it works again! Make sure after the tractor looses spark to put a circuit tester probe onto the negative side of the coil with the wire lead of the test light grounded to the engine, and spin the motor over. (The test light should light brightly, then go out as the points open and close!)If this does not happen, you have possible problems with the points and condensor, or even power to the entire ignition system altogether!
Good luck with it!
Rick
Aaron Jelinek
03-13-2001 09:40:52
I am looking for a precision model of Allis Chalmers WD .... Tx
randy
04-08-2000 11:15:59
She's running.Thanks for the advice.Randy
dave kolby
04-03-2000 16:10:14
Mine did that, condenser was bad, cheaper way to start than a coil.
Dave
Rick
04-02-2000 17:17:33
Sounds like it`s time for a new coil ,Send to Wisehart`s Mag repair, Central Indiana.
Sandy Lake Implement
04-02-2000 19:56:40
 Re: Re: allis-chalmers WD in reply to Rick, 04-02-2000 17:17:33
We stock the coil & we rebuild mags or exchange
them. We also have the OEM Allis right angle
conversion from mag to distributor-used $85
plus $50 for used distributor.
