What Transmission oil should I use for Allis-Chalmer C
Joe Holland
03-31-2000 08:29:04
I would like to find out for sure what is the correct oil to use in the transmission,rear end and hydrolic on an Allis-Chalmer Model "C"
Thank you in advance for your help.
Joe
Brian G.
04-03-2000 06:38:08
 Re: What Transmission oil should I use for Allis-Chalmer C in reply to Joe Holland, 03-31-2000 08:29:04
The original manual calls for 20W motor oil, but, as Nick says, today's modern universal hydraulic/transmission oils are your best bet. DO NOT use 80/90 Gear oil; although it might work if you didn't plan on using the hyraulics.
Nick
04-01-2000 20:37:19
The fluid I use is Traveller universal hydraulic fluid. It is 10W20 and can be used in tractors like the C that use the same fluid for the transmission and hydraulics. I buy it at tractor supply.
Anne Berendsen
12-09-2003 07:48:13
 Re: Re: What Transmission oil should I use for All in reply to Nick , 04-01-2000 20:37:19
I am looking for a material safety data sheet for Traveller Premium Universal Tractor Hydraulic Fluid SAE 10W-20. Do you know where I could get a copy of this?
Joe
04-02-2000 06:43:24
 Re: Re: What Transmission oil should I use for Allis-Chalmer C in reply to Nick , 04-01-2000 20:37:19
Thank you for the information. I'll give that a try,
Joe
Nick
04-01-2000 19:41:10
I use a universal hydrolic and transmision fluid. You can get it at any farm store.
Rick
03-31-2000 19:26:35
80 90 gear oil.
