My d15 has 30lbs compression on one cyl any ideas out there
brian
10-27-1998 17:25:57
my d15 is smoking very bad the smoke looks white but there is oil spitting out of the exhaust so i checked compression & one cyl has 30lbs so i put oil in the sparkplug hole &checked it again no change still 30lbs the other 3 cyls have 150 plus any ideas?
mongo
10-28-1998 15:23:38
 Re: my d15 has 30lbs compression on one cyl any ideas out there in reply to brian, 10-27-1998 17:25:57
: my d15 is smoking very bad the smoke looks white but there is oil spitting out of the exhaust so i checked compression & one cyl has 30lbs so i put oil in the sparkplug hole &checked it again no change still 30lbs the other 3 cyls have 150 plus any ideas?
Not familiar with your machine but it could be as simple as some collapsed rings or a blown head gasket. With the engine running, does the oil pressure stay fairley constant or does it jump all over the place when the low compression cylinder tries to fire? If it jumps all over, it could be because of the head gasket allowing the combustion chamber to talk to the oil gallery.
RJS
11-04-1998 14:58:41
 Re: Re: my d15 has 30lbs compression on one cyl any ideas out there in reply to mongo, 10-28-1998 15:23:38
: By this time you probably have the head off your D15, because that is where you have to look -- that is ,under the head. Some checks you can do before you yank the head are colour of the oil, listen for blow-by, and look at the coolant for signs of blowby (bubbles/surge). But this is rather academic in my oponion, since you gotta take the head off and have a look. If you are lucky, it will only be a head gasket. Good luck. I have a D15 Series II and I love it. Big enough to do the jobs I want, easy to get on and off, and it always starts! : : my d15 is smoking very bad the smoke looks white but there is oil spitting out of the exhaust so i checked compression & one cyl has 30lbs so i put oil in the sparkplug hole &checked it again no change still 30lbs the other 3 cyls have 150 plus any ideas?
: Not familiar with your machine but it could be as simple as some collapsed rings or a blown head gasket. : With the engine running, does the oil pressure stay fairley constant or does it jump all over the place when the low compression cylinder tries to fire? If it jumps all over, it could be because of the head gasket allowing the combustion chamber to talk to the oil gallery.
