Gallion GRader
jeff
03-30-2000 04:47:17
looking for a site for gallion road graders, need a manual and parts thanks
Vance
10-05-2004 18:05:52
 Re: Gallion GRader in reply to jeff, 03-30-2000 04:47:17
looking for a service manual for a Gallion 104H
Series B
Dennis Sipe
04-23-2001 12:57:09
I need part price and availability
Gallion Grader Part number 30860 gear
503A model thanks for your help
Thomas Inman
02-04-2001 16:57:44
We are looking for a large Nut, size 2 1/4 with 12 threads per inch for a T400 Gallion Road Grader. The nut fits on the Outer Rear Brake Drum
This Nut holds the Brake Drum On. Please let us know where we could possibly get one.
Thanks Much!!!
rich morley
02-07-2001 15:43:20
 Re: Re: Gallion GRader in reply to RonL, 04-17-2000 13:22:46
need a master cylinder for a 1966 t 500a
Phil auten
03-30-2000 08:28:39
Jeff,
Galion (this is the correct spelling) is still in business, but they have apparently been bought up by Komatsu, check your Yellow Pages for dealers. They should have manuals or reprints for real old stuff. I thought I had found a website, but it wouldn't come up. Try searching on Komatsu.
Phil
Sean
07-09-2002 12:53:09
 Re: Re: Gallion GRader in reply to Phil auten, 03-30-2000 08:28:39
I have had luck with getting parts for my Galion 160B maintainer from company called Walkasha Peirce. Check them out!
Good Luck,
sameer bhojani
07-05-2001 04:48:37
Actually i am looking for a part controller of gallion roller model no.1952. if it is available please send us the requirment of shipment and if not please guide us by providing the addresses of concerned companies.
with best regard
sameer bhojani
Phil Auten
03-30-2000 08:31:12
Try the link below.
Phil
STAN
03-20-2001 02:22:57
 Re: Re: Re: Gallion GRader in reply to Phil Auten, 03-30-2000 08:31:12
WHAT DO YOU WANT TO KNOW ABOUT A GALION GRADER
Greg
01-10-2003 17:55:20
 Re: Re: Re: Re: Gallion GRader in reply to STAN, 03-20-2001 02:22:57
I own a model 104 and interested in what motor is in it. It has an International emblem on the side of it, starts on gas, runs on diesel. Partial tag of UDF on motor. Serial number on tractor is MD18825. Thanks for any imput you may have
[email protected]
jim hanks
01-21-2002 15:14:45
A friend is in need of a parts book or mechanic's manual (or at least good advice) for a 1937 falion road grader as he is at a loss as to how to remove the wheel bearings/gear hub from the main drive axle without tearing something up. Concern is that inboard bearing on main axle in tandem box has failed, allowing full tandem drive box to wobble. Removal of bolts, which we assume holds bearing box inside drive gear box, has not allowed bull, even with a lot of pressure, (hub) gear removal. Please respond to [email protected]
