12 volt conversion
Mark W.
03-29-2000 20:27:47
when changing over to a 12volt system. can I change the light/charge switch,to a regular switch just for the lights? thanks for any help.
Rick in NC
03-30-2000 04:58:08
 Re: 12 volt conversion in reply to Mark W., 03-29-2000 20:27:47
Mark,
When I converted my 1950 Model B to 12 volts, I ran all the power from the starter terminal through a on-off toggle switch and then wires to the ignition and the lights. I wired an in-line fuse between the toggle switch and the push-pull switch that I use to control the lights. That way I won't accidentally leave on the lights when I turn off the ignition.
But, yes, you can use a standard push-pull switch for your lights.
Good Luck.
Phil Auten
03-30-2000 04:51:34
Yes. If you're going to use a GM 10SI alternator the charge rate is controlled by the built in regulator so the switch's only function would be lights anyway. You should be able to use the original switch for this if it still works.
Phil
