D17 clutch
Brue
10-26-1998 18:49:23
I have a problem with the high/low range. It seems that it is not engaging. the tractor moves very little. There seems to be no
presure on the lever at all. Is there a way to lock it in high range without pulling the tractor apart? Is their any other access to the bearing? I,m a wd45 guy
and this is my first. Any shop manuals out there? thanks
Dan D.
10-27-1998 15:41:10
 Re: d17 clutch in reply to Brue, 10-26-1998 18:49:23
: I have a problem with the high/low range. It seems : that it is not engaging. the tractor moves very little. There seems to be no
: presure on the lever at all. Is there a way to lock it in high range without : pulling the tractor apart? Is their any other access to the bearing? I,m a wd45 guy
: and this is my first. Any shop manuals out there? thanks
The clutch needs adjusting most likely. You adjust the clutch through the square shaped hole that's located behind the hand clutch lever. The I&T manual will tell how to adjust the clutch. Also, you can get copies of the original AC service manuals here from Yesterday's tractors.
