Change from mag to distributor
philo
03-27-2000 11:38:09
Does anyone know the correct procedure for changing from a mag to a distributor on a wd 45. Is it even possible? I am wondering how to get it timed properly. This is the second time the mag has acted up so I would like to change it over to a distributor b/c it is less expensive to work on. Any help would be appreciated.
philo
Gordon
03-28-2000 18:08:22
 Re: change from mag to distributor in reply to philo, 03-27-2000 11:38:09
Hi, A Delco distributor from a WC, WD or WD 45 will fit and function if you change the assembly at the flange mounting interface. The WD 45 assembly is a die cast right angle drive housing; the WC and WD are cast iron right angle drive housings - on the tractors I have seen and worked on. Time at (Fire position: 30 degrees advance) high idle and check at low idle (Top Dead Center: 0 degrees) There two timing marks on most of the fly wheels. Be sure it fires on top dead center at low idle - especially you ever hand crank the engine. Good luck, Gordon
Sandy Lake Implement
03-27-2000 17:10:52
We can supply you with a used OEM right angle drive conversion for $85 and a distributor for
an additional $50. e mail,or ph 724-376-2489
8-5 EST
