Snap-Coupler arm latches
Patrick
03-25-2000 16:16:49
I see pictures of D17s with a metal rod going through the big holes on the bottom of the latches. What purpose is the rod there for?
Brian G.
03-26-2000 05:04:43
 Re: Snap-Coupler arm latches in reply to Patrick, 03-25-2000 16:16:49
I have 2 WD-45s (one a '55 & one a '56) with the latches with the big holes at the bottom. My other '56 WD-45 and my brother's WD have the "plain" latches without the big holes. The WD-45 manual shows only the "plain" latches. I am also curious as to the purpose of the holes. Let's hope someone provides the answer. Brian G.
Dan
03-26-2000 12:25:15
 Re: Re: Snap-Coupler arm latches in reply to Brian G., 03-26-2000 05:04:43
I believe the large holes in the lift arm latches were designed for a pipe to hold the outer end of the lift arms apart. There was a certain type of traction booster hitch that needed this extra reinforcement. When turning with these implements there was a fair amount of stress sideways on the arms. I dont't think they were used until the D series tractors came out. Hope this helps.
