D13
03-25-2000 14:27:24
The B and C use the same engine. The B was first. B's are all wide front, most with fixes wishbone axle; C's are wide adjustable, narrow single, and narrow double. ALmost all of the parts are interchangeable. For implements, but there are a plow, muounted cultivator, mounted sickle bar mower, engine side weights, wheel weights, belt pulley, PTO, hydraulic pump that I own for my B. I've heard that there was a snap coulpe set up for the plows but I've never seen one. ANother legend is a front end loader. An aftermarket 3 point hitch will let you use modern implements, assuming your C has hydraulics, our you are willing to add them. Remember, these are light weight (about 2000#)machines, with about 20 HP, so size your implements accordingly. I run a 5' WOods belly mower on my B, with no problems. Enjoy your beast!
