WD 45 HELP
Jon ILL.
03-25-2000 09:41:55
Engine stuck, was running fine. I'm not even able to turn it over byhand, don't want to force anything. Thanks!
Hilltopper
03-25-2000 13:33:40
 Re: WD 45 HELP in reply to Jon ILL., 03-25-2000 09:41:55
If the starter is not siezed then you may have a flywheel bolt broken off and jammed. Try bumping the engine backward and see if it loosens up.
Rick
03-25-2000 12:19:10
Pull the starter out and see if the bendix is hung up keeping the motor from turning.
Jon ILL.
03-28-2000 19:08:37
 Re: Re: WD 45 HELP in reply to Rick, 03-25-2000 12:19:10
Thanks alot on the info. I took the starter out and most of the covers to inspec no luck. I'm thinken it's in the transfer, so she coming apart. sorry it took so long been busy thanks again!
