D-17 MANIFOLD PROBLEMS. NEED HELP!
MARK
10-22-1998 14:45:27
I HAVE A D-17.I HAD TO REPLACE THE MANIFOLD GASKETS FOR ONE OF THEM WAS BAD.SO I PUT NEW ONES ON .WENT OUT TO PLOW THEN IN ABOUT 15MIN I HAD A EXHAUST LEAK IN TWO OF THE NEW GASKETS (THEY WHERE GOOD FROM THE GET GO)THE NEW GASKETS WHERE JUST GONE. SO WHAT IS WRONG WITH THIS THING.
I PUT THEM ON REAL TIGHT
ACkingfarms
01-23-1999 18:45:43
 Re: D-17 MANIFOLD PROBLEMS. NEED HELP! in reply to MARK , 10-22-1998 14:45:27
: I HAVE A D-17.I HAD TO REPLACE THE MANIFOLD GASKETS FOR ONE OF THEM WAS BAD.SO I PUT NEW ONES ON .WENT OUT TO PLOW THEN IN ABOUT 15MIN I HAD A : EXHAUST LEAK IN TWO OF THE NEW GASKETS (THEY WHERE GOOD FROM THE GET GO)THE NEW GASKETS WHERE JUST GONE. SO WHAT IS WRONG WITH THIS THING.
: I PUT THEM ON REAL TIGHT
mm
10-22-1998 16:00:14
Your exhaust manifold is old the exhaust gaskets have worn out before. The exhaust manifold has eroded away, it is no longer flat. You need to have it machined true again. Later.
