ROPS Canopy for 6G?
Doug M.
10-20-1998 20:16:51
I have a AC 6G Crawler Loader with a Drot 4in1 - It appears that there are mounts for a ROPS canopy at the top of the shovel frame, but no evidence that there was ever was a ROPS on this machine. I would like to put one on if I can find an appropriate one from salvage. Has anyone seen a 6G with ROPS? Can you use a ROPS Canopy off another AC Crawler? Any Information would be appreciated. Thanks!
Murray Paddison
06-13-1999 02:16:12
 Re: ROPS Canopy for 6G? in reply to Doug M., 10-20-1998 20:16:51
My company Engineered Structures Australia Pty Ltd can manufacture a structure that will meet the requirement specified in Australian Standard AS2294, give me a call 61-8-92779344 or fax 61-8-93777933, regards
Guido
10-28-1998 19:13:54
I had a '72 HD6 dozer that had a factory open ROPS on it. It was a 6 point outfit that mounted above the radiator, at the front of the battery boxes and at the rear. It was hinged at the front of the cage so you could pull it forward for access to the fuel tank, etc. I would try a salvage yard like Blanda's or Heavy Equipment Loader Parts, etc. E-mail me if you want locations & numbers. : I have a AC 6G Crawler Loader with a Drot 4in1 - It appears that there are mounts for a ROPS canopy at the top of the shovel frame, but no evidence that there was ever was a ROPS on this machine. I would like to put one on if I can find an appropriate one from salvage. Has anyone seen a 6G with ROPS? Can you use a ROPS Canopy off another AC Crawler? Any Information would be appreciated. Thanks!
Danny Parker
03-25-2000 13:50:17
 Re: Re: ROPS Canopy for 6G? in reply to Guido, 10-28-1998 19:13:54
: I had a '72 HD6 dozer that had a factory open ROPS on it. It was a 6 point outfit that mounted above the radiator, at the front of the battery boxes and at the rear. It was hinged at the front of the cage so you could pull it forward for access to the fuel tank, etc. I would try a salvage yard like Blanda's or Heavy Equipment Loader Parts, etc. E-mail me if you want locations & numbers. : : I have a AC 6G Crawler Loader with a Drot
I have a ac 6g with rops. I don't know if it is factory or not. I'll send you a pix if you want it Danny
