Hydraulic cyclinder rebuilding
Craig
03-19-2000 20:51:17
Where can I find cylinder rebuilding kits. I have a small one that is used for picking up the cultivators, and a large one that goes on a pull behind cyclebar mower. I'm not sure, but was TOLD that the mower was a number 7 if this helps. Both cylinders are single acting.
Thanks,
Craig
M Russell
03-22-2000 09:56:10
 Re: Hydraulic cyclinder rebuilding in reply to Craig, 03-19-2000 20:51:17
Rebuilding cylinders is usually no problem. If you do not know what type seals are used in your cylinder you must take it apart and examine the type parts used in your cylinder. The most common are o-rings which are common shelf items for us, but there are other speciatly seals used that are easy to obtain. I'll try to help you if you have more questions.
Sandy Lake Implement
03-20-2000 17:13:13
E mail us with more info or ph 724-376-2489
8-5 EST. I think we can help.
