AC WD NO top end power
mjd
03-18-2000 21:44:59
AC WD NO top end power. The rocker arms have no babett left
90 lbs. comperson all cilnders. any ideas?
Dan
03-26-2000 12:49:00
 Re: AC WD NO top end power in reply to mjd, 03-18-2000 21:44:59
Make sure your air cleaner is not restricted. The tractor may run good but seems to have no power under load. These old oil bath air cleaners can have a lot of gunk inside that is had to remove.
John C-IL
03-19-2000 07:22:48
check for leaks around the intake manifold and carb flange. You can do this two ways. Use a pump oil can and squirt some oil around the flanges and see if it gets sucked into the manifold. The other way is to spray some ether or WD40 around the flanges and see if the engine speed picks up or changes. John
mjd AC WD NO top end power
03-28-2000 15:50:30
 Re: Re: AC WD NO top end power in reply to John C-IL, 03-19-2000 07:22:48
Have checked for vac. leeks none. Compresion is good
Plugs,wire,points,cap,all good.
gouener seems to be working
starts fine,idels fine but can't get hi rpm
it wants to die, seems to help alittle if i
use some choke. i've dun all the simpel things
that i can think off. STUMPED
