Piston rings on a WD 45 Diesel...
JDGnutt
03-16-2000 15:39:05
We are rebuilding a WD 45 Diesel with the little buda 6 cylinder engine.. Just got the pistons back from the machine shop and they only have four rings on them.. (3 compression rings and one oil ring) when we pulled out the piston they had 5 rings.. (3 compression and an upper and lower oil ring.. the lower ring is below the pin) We are using the old pistons, as they are in good shape, but are worried about the missing ring.. The machine shop says we don't need the extra ring on the bottem... but don't want to put it together with out being 100% sure.. Just wanting to know what everyone else thinks.. Thank for any info..
JDGnut
LRN
03-20-2000 12:45:23
 Re: Piston rings on a WD 45 Diesel... in reply to JDGnutt, 03-16-2000 15:39:05
JDGnut, Call Buda engine Co. @ 318 222 3348. They stock most parts for the smaller Buda engines. I talked to them about a month ago. I have a Coop with a Buda engine. Hope this helps.
Call
03-16-2000 22:35:00
Call ther company that made or sold the rings they should know
