B Battery Box Blues
Terry (NC)
03-14-2000 19:34:51
I believe the battery box on my B is original however the side is not removable. Is this possible, as everything I've seen or read says it should be. I'd like to complete an accurate restoration so this is important to me (and I'd also like to forgo the expense of a new one). Also, How thick should the wood insulators be? The top one is missing and the bottom one is just a rotten fragment.
Thanks in advance. Terry
Paul
03-18-2000 20:03:08
 Re: B Battery Box Blues in reply to Terry (NC), 03-14-2000 19:34:51
The wooden insulators originally were a material very similar to masonite. You can make them eassily from 1/8" thick masonite from any lumberyard. If you need a new box, see Roger VanCamp in Ft. Wayne, IN 219-747-3455 Paul
Paul
03-18-2000 20:02:36
Rick in NC
03-15-2000 04:47:01
Terry,
I have read that the older battery boxes did not have a removeable side. You had to unbolt the box from the torque tube and tilt the whole box to get the battery in and out.
I can't help with the wooden spacers.
Good Luck.
