D-15 power steering problems
brian
03-13-2000 17:43:27
my d-15 power steering doesnt hardly work any more . it leaks arond the bottom of the resivore a little when you put fluid in it. it only works for a few minutes then it gets hard to steer again . its not leaking out fast enough for this to be the problem any ideas ? ive replaced all seal and gaskets but it still seeps a little has anyone had this problem before ? thanks
Jeff
03-14-2000 17:35:50
 Re: d-15 power steering problems in reply to brian, 03-13-2000 17:43:27
I belive that the system is sucking air. You need to find that leak and get it stopped
DAVID
04-03-2000 23:08:14
 Re: Re: d-15 power steering problems in reply to Jeff, 03-14-2000 17:35:50
i have had the same thing in the past on my d17 & d19 i went to heavier oil [r&o hyd. oil] & fixed the problem i was using auto trans. fluid
