AC6080
COl
03-13-2000 09:15:17
There is an AC 6080 coming up on auction with less than 3500 hours on it. It has a cab with air conditioning. Is this a very good tractor? What were some of the problems with it? What would the tractor be worth?
Jeff
03-14-2000 17:42:52
 Re: AC6080 in reply to COl, 03-13-2000 09:15:17
A very good tractor one of the best A-C made. The biggest problem we had was with the clutch both of ours had loaders on them and alot of different operators and this was most of the problem. They had a very good motor and the 4-wheel drive worked very good. Make sure the clutch works go
lee
03-13-2000 17:17:49
I am not an expert on these but thay did have a problem with crankshaft thrust brg. wear. from what i am told thay had an update witch consisted of an external brg. assembly mounted by the front crankshaft pulley witch eliminated the problem. check this out as most were fixed under warranty. otherwise, these tractors were a powerhouse, advertised at 80hp, most came 90+ from the factory. I seen one sold at auction last year without a cab for 10500.00 lo hrs. and clean. hope this helps you out.
A-C
03-13-2000 15:41:08
Link
Go to this board and ask. Usually good input on this site. Good luck.
