Re: WD rear wheel corrosion
Phil Snow
03-13-2000 03:43:48
Repair is relitively simply. Weld a thin plate over the rusted valve stem area and grind the edges smooth.Important to have no rough edges to nick the tube. Drill another hole for valve stem in another location on rim where little corrosion has taken place.Important to inspect and clean entire inside rim for sharp edges etc. The rim may be too far gone when you see the inside.
Phil
