FYI AC G Rings
Marvin
03-12-2000 07:52:59
Here's a good tip for anyone installing piston rings in a "G". As you know the rod ends are too big to go through the cylinder bores, and must be R&Rd from the bottom. Removing is easy, going back in is another story! The bottom of the bores are chamferd 45 degrees, and the manual says put them in from the bottom. There is barely room for your fingers let alone any tool. Heres what to do. Install oil rings only, as they will easily go in. Push piston through far enough for top ring grooves to show, install compression rings, tap down. It works!!! Marv
Dick L
03-12-2000 08:33:48
 Re: FYI AC G Rings in reply to Marvin, 03-12-2000 07:52:59
I have never worked on a G. I keep looking at them so one day I might. Thanks for a great tip. That is one tip I won't forget. Thanks again.
Rick
03-12-2000 16:09:15
 Re: Re: FYI AC G Rings in reply to Dick L, 03-12-2000 08:33:48
If you would use a ring compressor that would let you install pistons and rings all togetter.
