D17 front swap
nf to wf
Scott
03-12-2000 05:19:39
I have an early (s/n 8831) D17 with a narrow front and factory power steering. I also have an early wide front without power steering. How easy is it to swap the wide to the ps tractor, and the narrow to the non-ps tractor?? Thanks
Scott
D-17DAVE
03-12-2000 17:01:59
 Re: D17 front swap - nf to wf in reply to Scott, 03-12-2000 05:19:39
I made a simalar swap, both with power steering. Should be a close swap, but here are some things you might run into. A couple of extra holes are needed to mount the rear pivot point on the diesels, on the gas they should be there. I don't think you need to swap the gearbox, just unbolt the bolts on the tricycle vertical section and slide it down and off. The front pivot casting unbolts the same way and swap between both tractors. I ran into a problem with the bolt pattern. The pattern was the same but the bolt sizees for the front pivot casting were larger on the wide front. You may not have this problem as I used a wide front off a D-19. Just a thought you might get the rest of the stuff (ie) pump, brackets, front gear power valve assembly, etc. to convert both to power while your into it.
