Wd45-d17 engine
lee (mn)
03-11-2000 09:00:37
can anyone tell me the differences between the 226 gas engines in these tractors other than the rated speed and compression ratios. I have a 226 that i am trying to identify, it has a full flo oil filter. also what were the s/n of the 17 motors i know the wd motor s/n started with a w my motor is stamped 17-82876-v thanks.
Karl in MD
03-11-2000 16:19:59
 Re: wd45-d17 engine in reply to lee (mn), 03-11-2000 09:00:37
Sounds like what you have is an engine out of a D-17 Series IV. The full flow filter and the post 75,000 serial number are the keys. The block is a totally different casting due to the lubrication system, I'm not really sure which of the internals were changed, or how.
Paul Anderson
03-11-2000 15:49:00
Lee, one differnce and the only one I know of is in the 17 motor the crackshaft and rod jounals are larger than in the 45 motor, hope this helps, Paul Anderson, Shelby, Ohio
lee
03-11-2000 20:03:37
 Re: Re: wd45-d17 engine in reply to Paul Anderson, 03-11-2000 15:49:00
Thank you very mutch karl and paul for the info. a friend gave it to me to replace the engine in my wd and it did not look the same. it sounds like a lucky find. again thanks. Lee
