WD-45
John C-IL
03-05-2000 16:49:22
Happy Days, Got got my WD45 home. Purchased with a 3 bottom plow,posthole digger,and blade. Have one share missing from plow. Post hole is great condition. Blade hitch has been cut off and a trailer hitch installed. I may part with that. Went to a machinery auction Friday and bought a 4 row cultivator, front mount for $35 all there but needs paint and some TLC. Also found a snap-coupler sickle mower for $30. Put the ole girl right to work pulling trees that I dug out with my backhoe. I problem. Missing fire in #4. Think I have it narrowed down to spark plug. I have spark at the connection, compression and fuel. Has AC 44's. Anyone have suggestions before I buy a set of plugs.
John
Phil Auten
03-06-2000 04:40:56
 Re: WD-45 in reply to John C-IL, 03-05-2000 16:49:22
John,
Go one heat range hotter than what you have in there now. If it still fouls the plugs, go up another heat range. I've had this same problem on three different gas tractors. The gas we get today is really the culprit, especially if the tractor isn't working real hard. I now run Champion D-21Y plugs in all my working tractors with no fouling problems.
Phil
tadams
03-06-2000 04:31:01
If you still have miss after replacing spark plugs try adjusting carb.
Tom
Sandy Lake Implement
03-05-2000 19:18:05
Anything BUT Champion!!!!
John C-IL
03-06-2000 17:34:28
 Re: Re: WD-45 in reply to Sandy Lake Implement, 03-05-2000 19:18:05
Thanks guys, she runs like a champ, fire in all 4 holes. Also, saw something on the tractor I hadn't seen before. It has this hinge thingy on the seat that lets you flip it over to the right. I suppose so you can leave it out and protect it from the weather. It made you set off to the left about 3 inches, very uncomfortable so I have removed it. Has any one else seen this hinge?
Brian G.
03-07-2000 05:11:04
 Re: Re: Re: WD-45 in reply to John C-IL, 03-06-2000 17:34:28
I bought a WD-45 last summer that has this feature. I think it was designed to allow the driver to stand while driving. I don't know if it was sold by A-C as an option or it was an aftermarket item. I've never seen a picture of it in any of my manuals.
