WD45 Serial Number
PJS
10-11-1998 09:11:42
Could someone please tell me where to find the tractor serial number. I know it's on the left differential brake housing- but what exactly is the left differntial brake housing? I don't want to sound stupid, but every time I look I can't find it. I would apprediate your help.
Jonathan
10-13-1998 19:47:30
 Re: WD45 Serial Number in reply to PJS, 10-11-1998 09:11:42
look from the back of the tractor, look on the axle (brake housing) on the left side. The should be 6 numbers stamped into the back of the brake housing. The brake housing is the big round thing that also includes the axle that on both ends of the axle are the 2 back tires. these 6 numbers are there as plane as day. should be real easy to locate.
: Could someone please tell me where to find the tractor serial number. I know it's on the left differential brake housing- but what exactly is the left differntial brake housing? I don't want to sound stupid, but every time I look I can't find it. I would apprediate your help.
R. Lemmert
10-11-1998 20:49:42
It's to the left of the gear inspection plate above the square head bolt and nut lock. {Brake Adjustment} just below the hole where the spring comes through on a flat machined surface. Take a sharp putty knife or sharp wood chisel and scrape old paint and rust away it should be there. My number is 184648 yr. 1954.
R. Lemmert
R.Lemmert
10-11-1998 20:03:55
It's to the left of the gear inspection plate, above the square head bolt and nutlock {break adjustment}Just below the hole where the spring comes through on a flat machined surface.Take a sharp putty knife or sharp wood chisel and scrape old paint and rust away, it should be there.Mine has a number 184648 1954.Anymore ? just e-mail me.R.Lemmert
Robert Lemmert
10-11-1998 19:47:10
: Could someone please tell me where to find the tractor serial number. I know it's on the left differential brake housing- but what exactly is the left differntial brake housing? I don't want to sound stupid, but every time I look I can't find it. I would apprediate your help. PJS, I can tell you where it is.Can you give me your e-mail address?
